xMsg javascript has not been loaded.
project_custom_field_values_by_id: Teamleader Project Custom Field Values by ID |
Contents Previous Home Next More |
Catalog: Teamleader
Schema: V1
Primary Keys: id
Label: Project Custom Field Values by ID
This is a read-only table function. The Teamleader API may not support changing the data or the Invantive SQL driver for Teamleader does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Teamleader API.
Select Teamleader API URL: getProject.php
Insert Teamleader API URL: getProject.php
Update Teamleader API URL: getProject.php
Delete Teamleader API URL: getProject.php
Base Path: custom_fields
The following parameters can be used to control the behaviour of the table function project_custom_field_values_by_id. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be treated using their default values.
Value specification by position is done by listing all values from the first to the last needed value. For example with `select * from table(value1, value2, value3)` on a table with four parameters will use the default value for the fourth parameter and the specified values for the first three.
Name |
Data Type |
Required |
Default Value |
Documentation |
project_id |
decimal |
The columns of the table function project_custom_field_values_by_id are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
id |
int32 |
ID |
key |
int32 |
Key |
position |
int32 |
Position |
value |
string |
Value |
12-12-2020 19:52 Version 20.1.301-BETA+3023
