xMsg javascript has not been loaded.
Catalog: Teamleader
Schema: V2
Primary Keys: id
Label: Products
This is a read-only table. The Teamleader API may not support changing the data or the Invantive SQL driver for Teamleader does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Teamleader API.
Select Teamleader API URL: products.list
Insert Teamleader API URL: products.list
Update Teamleader API URL: products.list
Delete Teamleader API URL: products.list
The columns of the table Products are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
code |
string |
description |
string |
Description |
id |
string |
ID |
name |
string |
Name |
12-12-2020 19:52 Version 20.1.301-BETA+3023
