products: Teamleader Focus Products |
Catalog: Teamleader
Schema: V1
Primary Keys: id
Label: Products
This is a read-only table function. The Teamleader Focus API may not support changing the data or the Invantive UniversalSQL driver for Teamleader Focus does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Teamleader Focus API.
The following parameters can be used to control the behaviour of the table function products. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
modifiedsince |
datetime |
Select products modified and/or added since this date. |
searchby |
string |
A search string. |
The columns of the table function products are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
booking_account_id |
int32 |
Booking Account ID |
booking_account |
string |
Booking Account |
date_formatted |
string(20) |
Date (Formatted) |
external_id |
string |
External ID |
id |
int32 |
ID |
name |
string |
Name |
price_value |
float |
Price Value |
stock |
int32 |
Stock |
total_price_excl_vat |
float |
Total Price excl. VAT |
vat |
string |
VAT |
10-06-2024 18:37 Version 24.1.3-BETA+4689
