project_custom_field_values_by_id: Teamleader Focus Project Custom Field Values by ID |
Catalog: Teamleader
Schema: V1
Primary Keys: id
Label: Project Custom Field Values by ID
This is a read-only table function. The Teamleader Focus API may not support changing the data or the Invantive UniversalSQL driver for Teamleader Focus does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Teamleader Focus API.
The following parameters can be used to control the behaviour of the table function project_custom_field_values_by_id. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
project_id |
decimal |
The columns of the table function project_custom_field_values_by_id are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
id |
int32 |
ID |
key |
int32 |
Key |
position |
int32 |
Position |
value |
string |
Value |
10-06-2024 18:37 Version 24.1.3-BETA+4689
