Teamleader Focus Forums
Navigation: Catalog: Teamleader > Schemas > Schema: V2 > Tables
Products: Teamleader Focus Products
Catalog: Teamleader
Schema: V2
Primary Keys: id
Label: Products
This is a read-only table function. The Teamleader Focus API may not support changing the data or the Invantive UniversalSQL driver for Teamleader Focus does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Teamleader Focus API.
The following parameters can be used to control the behaviour of the table function Products. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
term
Search for term in name and code.
updated_since
date
The columns of the table function Products are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
added_at
datetime
Added At
c_artikeltext
varchar2
code
varchar2
configuration_stock_threshold_action
varchar2
Configuration Stock Threshold Action
configuration_stock_threshold_minimum
decimal
Configuration Stock Threshold Minimum
description
varchar2
Description
id
varchar2
ID
name
varchar2
Name
stock_amount
decimal
Stock Amount
unit_id
varchar2
Unit ID
unit_type
varchar2
Unit Type
updated_at
datetime
Updated At
Disclaimer
