xMsg javascript has not been loaded.
solution_article_attachments_by_id: Freshdesk Solution Article Attachments |
Contents Previous Home Next More |
Catalog: Freshdesk
Schema: Freshdesk
Primary Keys: id
Label: Solution Article Attachments
This is a read-only table function. The Freshdesk API may not support changing the data or the Invantive SQL driver for Freshdesk does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Freshdesk API.
Select Freshdesk API URL: /solutions/articles/{id}
Insert Freshdesk API URL: /solutions/articles/{id}
Update Freshdesk API URL: /solutions/articles/{id}
Delete Freshdesk API URL: /solutions/articles/{id}
Base Path: attachments[*]
The following parameters can be used to control the behaviour of the table function solution_article_attachments_by_id. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be treated using their default values.
Value specification by position is done by listing all values from the first to the last needed value. For example with `select * from table(value1, value2, value3)` on a table with four parameters will use the default value for the fourth parameter and the specified values for the first three.
Name |
Data Type |
Required |
Default Value |
Documentation |
id |
decimal |
The columns of the table function solution_article_attachments_by_id are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
agent_id |
int64 |
Agent ID |
attachments_attachment_url |
string |
Attachments URL |
attachments_content_type |
string |
Attachments Content Type |
attachments_created_at |
datetime |
Attachments Created at |
attachments_id |
int64 |
Attachments ID |
attachments_name |
string |
Attachments Name |
attachments_size |
int64 |
Attachments Size |
attachments_updated_at |
datetime |
Attachments Updated at |
category_id |
int64 |
Category ID |
created_at |
datetime |
Created at |
description |
string |
Description |
description_text |
string |
Description |
folder_id |
int64 |
Folder ID |
hits |
int64 |
Hits |
id |
int64 |
ID |
seo_data_meta_description |
string |
SEO Description |
seo_data_meta_keywords |
string |
SEO Keywords |
seo_data_meta_title |
string |
SEO Title |
status |
int64 |
Status |
title |
string |
Title |
tumbs_down |
int64 |
Thumbs Down |
tumbs_up |
int64 |
Thumbs Up |
type |
int64 |
Type |
updated_at |
datetime |
Updated at |
12-12-2020 13:14 Version 20.1.301-BETA+3023
