Error itgendoc001X
xMsg javascript has not been loaded.
Freshdesk API Data Model
Navigation: Schema: Freshdesk > Tables
solution_article_by_id: Freshdesk Solution Article
Contents Previous Home Next More
Catalog: Freshdesk
Schema: Freshdesk
Primary Keys: id
Label: Solution Article
This is a read-only table function. The Freshdesk API may not support changing the data or the Invantive SQL driver for Freshdesk does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Freshdesk API.
Select Freshdesk API URL: /solutions/articles/{id}
Insert Freshdesk API URL: /solutions/articles/{id}
Update Freshdesk API URL: /solutions/articles/{id}
Delete Freshdesk API URL: /solutions/articles/{id}
Table Function Parameters
The following parameters can be used to control the behaviour of the table function solution_article_by_id. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be treated using their default values.
Value specification by position is done by listing all values from the first to the last needed value. For example with `select * from table(value1, value2, value3)` on a table with four parameters will use the default value for the fourth parameter and the specified values for the first three.
Name
Data Type
Required
Default Value
Documentation
id
decimal
Table Function Columns
The columns of the table function solution_article_by_id are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
agent_id
int64
Agent ID
category_id
int64
Category ID
created_at
datetime
Created at
description
string
Description
description_text
string
Description
folder_id
int64
Folder ID
hits
int64
Hits
id
int64
ID
seo_data_meta_description
string
SEO Description
seo_data_meta_keywords
string
SEO Keywords
seo_data_meta_title
string
SEO Title
status
int64
Status
title
string
Title
tumbs_down
int64
Thumbs Down
tumbs_up
int64
Thumbs Up
type
int64
Type
updated_at
datetime
Updated at
12-12-2020 13:14 Version 20.1.301-BETA+3023
