HubSpot Forums
Navigation: Catalog: Automation > Schemas
AutomationFlows
Retrieve workflowsRetrieve a list of automation flows with optional pagination using the 'after' and 'limit' query parameters.
Catalog: Automation
Schema: Basic
Retrieve: true
Insert: true
Update: false
Delete: false
The following parameters can be used to control the behaviour of the table function AutomationFlows. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
after
The columns of the table function AutomationFlows are shown below. Each column has an SQL data type. A new non-null value must be provided for every required column at all times during insert.
Name
Data Type
Label
Required
Documentation
createdAt
datetime
Created at
The date and time when the automation flow was created, formatted as a date-time string.
flowType
varchar2
Specifies the type of the automation flow (PLATFORM vs. CONTACT)
id
varchar2
ID
The unique identifier for the automation flow.
isEnabled
char
Indicates whether the automation flow is currently active.
name
varchar2
Name
The name assigned to the automation flow.
objectTypeId
varchar2
Ojbect Type ID
Represents the ID of the object type associated with the automation flow.
revisionId
varchar2
Revision ID
The identifier for the current revision of the automation flow.
updatedAt
datetime
Updated at
The date and time when the automation flow was last updated, formatted as a date-time string.
uuid
varchar2
The universally unique identifier for the automation flow.
Disclaimer
